I've created a wonderful widget i am very happy with on my phone using KWGT Pro. When I try to move it over to my tablet, however, it does not work.
I export the .kwgt file from my phone and save it on google drive. I have checked the kwgt file from my pc and the zip looks correct. I download the kwgt file on my tablet and move the file to kwgt / widgets. Then, when i go to create the widget on the tablet, it shows in the "exported" tab properly... but, after i select it, it spins for a moment... then backs out to the home screen with just the default black box where the widget should be.
