Can I change multiple global variable using shortcut?
I want to change global variables a and Menu to 0 using Nova gesture (home button). Is this possible?
(Changing two variables using one shortcut)
Yes you can do that, do the following:
  • Set the Nova gesture to open a shortcut
  • Select the "Kustom Action" one
  • A dialog should open, you can select the global name and what to do
can it change two variables at a time?
