So I use Google calendar and my evens show up on the preview within kwgt but not on the actual widget on the home screen
Your calendar events show in other kwgt widgets? Do you make this widget or is one from other designer? You have the Google calendar like your Calendar to look in the Menu(the 3 lines in the top left of the editor) > Configuration> Calendars to look?
