Bugged when selecting shortcuts
Hi I'll try to explain my problem:
I select shortcut 1 and edit it, then when I select shortcut 2 and hit edit it's still shortcut 1, same if I select shortcut 3 and edit still shortcut 1.
What can I do? Ty
I have tried to add 2 shortcuts to the same object and it works, you mean the shortcut window on the root? Can you provide a simple preset with the issue?
I made a gif of the problem http://im.ezgif.com/tmp/ezgif-613693327.gif
as you can see I can't edit any shorcut but the last one no matter which one I select
BUMP?
Sorry that video is lost, can you either attach it here or provide a way to reproduce the issue?
https://youtu.be/F3yeFNw09q8
I uploaded it, sorry! and thanks
Thanks! Issue might be related to the fact that items have all the same name, can you also share the preset so i can try to understand whats going on?
Yes thanks for all your help, here is the preset:
https://drive.google.com/open?id=0B8k78YLeYpUmdHlQYVg4ZURKOXM
And about all the items having the same name, it's because the same stuff is just selecting last item no matter which one I choose
Thanks, will fix in next releease
