Brocken transparency
The transparency is broken.
How to recreate: Create a form. Set transparency. Apply BG. Transparency is full color.
Device: S24U
OS: Android 14 OneUI 6.1
Preview:
Result:
I have the exact same phone (and OS and UI) as you and I can’t reproduce this problem.
What version of KLWP are you running?
klwp version is: 3.76b422110
I am not sure how exactly it behaves… as to now it seems to work. and yet sometimes it doesn’t.
Okay.
Well maybe Frank or someone else can shed a light on it…
Try disabling parallel rendering and see if that helps. Settings >> Advanced options >> Turn on “Disable Parallel Rendering”.
