Bitmap weather icon
Hello,
I've tried the instruction on custom weather icon using zip file from your upload.
I unlock in the 'global' tab all icons and pointing each icon to corresponding extracted file in my sd card. But when I lock the icon, the path seems back to default (see attached).
Pls advise, thank's
The path might be fine, is it working? Because that path might also point to the SD card (and BTW you do not need to lock the globals back, just export the Komponent again and reload it to test if it works)
Hi Frank, it seems working. See attached. I hope in the future you can :
- Add more weather provider (free of course!) :)
- Zoomimg ability in advance editor
- Moving object in advanced editor with tap and drag, so it could make editing faster. And to be precise in positioning, zoom can become handy.
Thank's
