Big widget after create
I use KWGT a few weaks. I have setup a few widgets.
When I setup the just size and save the widget some time the widget look big.
I don’t see some things from the widget.
What is the reason this happen and how solve this?
I’m not sure why this is happening (not enough info), but if you are in the editor and in the root of the widget you can go to layer and set the scale.
