In KLCK, the battery status code (bi(level)) has stopped updating the battery status for a few days. The lock screen loads the battery value when the phone is turned on and then does not update it. It worked perfectly for the last few years, it broke a few days ago.
Check if version 3.78b510818 is already available for you in the Play Store. If not, sideload it from the link below and check if the issue persists.
