Battery level 30 minutes ago doesn't update
Hello, I used the bi(level, r30m) code before the uppdate and it worked just fine. But after the update (v3.44b5017) it return constant value and doesn't update. Is it a bug? or is it permission problem? I'm running Android 10 One UI 2.0 Is ther a way to fix it?
I have the same issue, reverted to v3.43 and now it works as before.
How do you revert it? sideload it? or is ther a way to revert it back from playstore
Downloaded https://kustom.rocks/download/KWGT/381, uninstalled KWGT, installed the downloaded apk. Switched off autoupdate in play store.
You can download older versions from this Web site. Look under downloads on the main page.
