battery info in Kustom Lock shows wrong value always at 100% tried everything and it was working good for couple weeks.
galaxy s24 ultra
android 14
app v. 3.78b510607
galaxy s24 ultra
android 14
app v. 3.78b510607
Check if version 3.78b510818 is already available for you in the Play Store. If not, side load it from the link below.
same here battery variable doesn’t show correct information or update . its stuck on unplugged moments ago
i updated to latest version but the problem is sitll there
Can confirm this issue came after latest version to fix widget not loading. @frank
Same there, I confirm issue from last update
Do you guys experience the same issue even on version 3.78b510818?
This was a beta issue and has been fixed in 3.78b510818 sorry for the issue, update is also available on the play store
