Backgrounds render in blurry
When setting the wallpaper, the background renders in blurry.
Maybe you are using an image that its too big or your device is out of memory, does it happen also with small setups? Did you try a reboot?
The image being too small is not an issue as I can get the image to render in completely. The memory being out is an interesting idea. Perhaps that would be the issue.
