Hello! I'm making an animation in klwp. It seems to work find in the editor but when I apply it, I won't work anymore. Hope to have it solved. Just got the key for pro version of it
Please check the FAQ, in particular:
Wallpaper is not scrolling!
Please ensure that you have "background scrolling" enabled in your Launcher settings, for example, in Nova, you can find this in "Settings -> Desktop -> Wallpaper Scrolling". Then ensure that the image you set as background is larger then your screen (if you cropped it to screen size it wont scroll because there is nothing to scroll). Finally ensure that the number of screens in your launcher have the same count as the ones on the preset you are using.
