Hello,
I have found a bug with using equations in animation parameters. Specifically, when using a global variable in a komponent's animation the global variable is counted as 0. Normal equations work, and I can use other variables, but not globals from the komponent. I have created an example that shows this affect using the delay parameter. Basically, it animates 4 circles, and in text shows what the delay should be and what it actually is due to the error.
Thanks!
