Alternate between two literals on a timer?
Is there a way to alternate between two literals on a timer? Say I want to alternate the width of a shape between 100 and 150 every 5 seconds, or alternate saturation of an image between 0 and 100 every second to act as a flashing effect(trying to come up with a workaround for no animations in kwgt)
You can use something like this "tu" formula
$if(tu(rnd,1/60,0,1)=1,0,100)$
This are going to change between 0 and 100 every second.
Take in mind that the actualization every second in Kwgt can drain your battery.
This works, thank you. I racked my brain for hours trying to figure out how to make this work using sequence. I never thought to use random and set the count from 0 to 1
