Hello I am trying to make a widget that just displays album art. I know how to set it up using thr bitmap, and I get it to recognize what album is being played, but the image never shows in the editor or on my home screen. Help
Hi! So in order to ensure Music works please check the following:
- Kustom has access to Notifications (it should ask you when you save)
- You started your music player at least once (Kustom detects automatically the player being used)
- Ensure the Player properly shows a Notification
- If cover doesnt work ensure your player (Poweramp for example) doesnt have an option to hide the cover in the Lockscreen
- Try to reboot once, this sometimes is needed when Kustom is upgraded (you can also try reinstalling worst case)
- Some player might not work, in most cases this is related to the player not implementing Android standards (usually test can be done with Google Music which is fully supported)
Thanks!
