Alarm detection not working on MIUI
Hello, the regular detection method does not work on my Xiaomi Redmi Note 3 pro, it does not show the correct alarm, just some random hour, i have set to 10:30 and the alarm value on custom lockscreen says 12:00. Could you look into that?
Yeah this is a MIUI bug, there is a potential fix on next release that might solve or at least mitigate this, please check once out
Hi, it's been 8 months and the alarms are still not detected correctly. Is this beeing worked on? Is there any kind of a workaround?
Still broken with MIUI 11.
