Adding animations to objects inside a komponent (changing rotation center)?
This might be a feature request, depending on the answer. I'm trying to get an image to rotate along its bottom right corner (not in the center). YouTube says I can add an animation to the object, but that doesn't seem to be an option for the objects within the komponent. Am I missing something? Is there another way to accomplish what I'm trying to do? If the answer to both is "no", I'd like to request a way :)
What you can make is add an animation to the whole komponent, if the kompo have the image and other items, all are going to rotate, what you can make is copy the image outside the komponent put it in the root of the preset or inside an overlap group and make it rotate it like you want.
At this moment you can't make individual animations inside Komponents or stack groups or Overlap groups, the developer explainded it to other users that make the request, that it's very difficult to implement this, you can search in this page for this request, and if you want you can make the request too.
Is there another way I can make something rotate from a corner, rather than the center? That's all I'm trying to do really. I tried searching other people's questions, but I couldn't find anything.
I think that you can set the Anchor of the rotate animation to the corner that you want, you need to play with this a little, if you haven't luck, come here again and explain a little your animation, when you have the animation set, go out of the editor and test it in your screen, in some animations the editor is not totally reliable.
