How can I add a line (rectangle) with an angle without using overlap group?
Because it is difficult to measure the distance when using overlap group to rotate
You can rotate a line even in the root, just set rotation to manual in the shape element, isnt that what you are looking for? Next version will also allow rotation X/Y offset in root elements.
Thank you so much
I can't see the rotation option because my small phone can't display all the option until I scroll down the screen
Thank you
Would be nice to maybe have an option to use points to add a line (like x1,y1 and x2,y2 + width).
This way it's easy to add graphs as well.
A simple start/end x, y line object would make life so much easier!
