Add a Crescent Shape
I would like it if a Crescent was one of the optional shapes to choose from. I'm trying to recreate the moon's phase visually and having this Shape would do the trick.
You can probably do the same using a Komponent with 2 circles inside first one normal filled, second one with paint mode set to CLEAR and off course a different offset
hye I've made one with crescent if you're still interested in with real crescent not offset.
You can do this via path shapes now, i have added a tutorial:
https://docs.kustom.rocks/docs/recipes/shapes/crescentmoon/
This requires version 3.73
