It would be great if this could interact with the KLWP app. Like you can make a widget that makes an object rotate, for example.
It would be like this:
1. You set the animation to trigger on a "signal" and set an ID or a name for the signal
2. You go into KWGT and there in the touch, set it to "trigger animation" and then you put the trigger ID so when you touch it it triggers the animation on the wallpaper.
