Ability to adjust triangle corners
Please, add an ability to adjust triangle corners as other shapes (rectangle, square) has. It is pain to create own triangles using 3 rectangles with adjusted corners.
Thanks in advance.
You mean rounding corners?
Yes, same as square and rectangle has.
Is it possible?
Available in 3.48
